unconfigure l2vpn vpls redundancy
unconfigure {l2vpn} vpls vpls_name redundancy [eaps | esrp | stp]
Description
Disassociates the VPLS instance from EAPS, an ESRP domain, or STP.
Syntax Description
vpls_name Specifies the VPLS for which you are removing protection.
eaps Disassociates the VPLS instance from EAPS.
esrp Disassociates the VPLS instance from the ESRP domain.
stp Disassociates the VPLS instance from STP.
Default
Redundancy disabled.
Usage Guidelines
The l2vpn keyword is introduced in ExtremeXOS Release 12.4. For backward compatibility, the l2vpn keyword is optional. However, this keyword will be required in a future release, so Extreme Networks recommends that you use this keyword for new configurations and scripts.
The following command disassociates the VPLS instance from ESRP:
unconfigure l2vpn vpls vpls1 redundancy esrp
The l2vpn keyword and the STP option were added in ExtremeXOS 12.4.
Platform Availability
This command is available only on the platforms that support MPLS as described in the Switch Engine v33.1.1 Licensing Guide document.
